The intention of this proposal is to suggest an easy to implement alternative to the issue created by the Windows 10 deprecation of SMB1. Such a solution could prove to be a competitive advantage ov...
jmaclabs
Apr 11, 2020Novice
Well put and stated. This feature does not work as documented nor does the feature/functionality support obvious use cases, like, needing admin pwd for client access, or, all access without a password.
