DiggyDid's avatar
DiggyDid
Status:
New Idea
Remove disconnected satellites on Nighthawk Mesh WiFi 6
I bought an MK62 (1 router, 1 satellite) thinking the ethernet port on the satellite was a switchport (alas, it's only used for backhaul - no worries).  Because the upgrade improved my wireless signal, I no longer need the satellite.  I have a friend with the exact same system who can use my satellite so it doesn't go to waste.  However, there is no way to remove the satellite from my network map.
Please add functionality to remove/reset satellites from the network.
Comments have been turned off for this idea
