jpotts2012's avatar
jpotts2012
Follower
May 14, 2020
Status:
New Idea
Remove TLS 1.0 from current device firmware
It has come to my attention that the Netgear R6700v3 with firmware v1.0.2.52_1.0.39 is still running TLS 1.0 and will create flags for PCI Security Scans.  I suggest removing this TLS v1.0.
Other PCI Security Scan Results that are an issues that I have run into and need to be resolved are:
1) Block cipher algorithms with block size of 64 bits
2) Insecure SHA-1 Certificate Signature Algorithm
3) SSL Certificate Public Key Too Small
4) SSL Certificate signed using a weak hashing algorithm
5) SSL RC4-based Ciphers Supported
6) SSL/TLS Weak Encryption Algorithms
7) SSLv2, SSLv3 and TLS v1.0 Vulnerable to CBC Attacks
Aditionally a 3rd party SSL Certificate needs to able to be added for better security.
Comments have been turned off for this idea
