Ok night hawk needs a reboot Schedule option in router settings. It should be very simple to add this since firmware automatically restarts the router or if you change WiFi security codes. There needs...
JimTheGreek
Oct 20, 2020Tutor
I agree. It's needed to keep it clean running! Almost ANY 'smart' device runs better after a reboot!
Hey, Netgear, have you put the Nighthawks on back burner already? I have not seen any new stuff for it since I purchased it.
