Please return support for separate SSID's for the bands. I have some IOT devices that do not support 5GZ and will not connect to the orbi. I have to maintain a seperate AP for them
The_Jerry
Dec 17, 2020Fledgling
there is no working description how to get those 2.4ghz iot devices working with an rbr750 system.
Telnet option is not availabel in debug.htm, enableTelnet scripts do not work. setting power for 5ghz to 25% does not help.
Need to setup a special AP just in case I want an iot device added to my network. Netgear should provide a solution - disable 5g temporarily for the home network, force a device to 2.4 ghz temporarily or something else.
