Hello NG. I think it would proove wise and useful if you did your uttermost best to support HomeKit at least for your existing wifi 6 mesh systems, including those built around rbr850. As many other ...
adhocs
Nov 16, 2020Follower
adhocs wrote:Hello NG. I think it would proove wise and useful if you did your uttermost best to support HomeKit at least for your existing wifi 6 mesh systems, including those built around rbr850. As many other manufacturers with less experience than you release firmwares for their existing mesh kits and Apple is registering more competing products offering HomeKit it would be, as said, wise and about time to offer that support to your customers so that in the future they don't have to rethink again their options regarding flexibility and compatibility of your range. Arnaud D
Thankyou for your answer. I m not that sure that VELOP linksys wifi 6 mesh will be able to support HomeKit, as I owned them before, complained about their caractérial instability compared to orbi wifi 6 mesh I m using now and was told that HomeKit support would be for the lower range product offering doubleband. So I returned the velops who did’nt offer specific and privileged wireless backbone between the stations for the orbi and I can see everyday the difference. And also the velops have less settings available to tweek them what needs to be done at least weekly as in my experience 3 velops are to much to handle for the linksys.. Arnaud
