Hello NG. I think it would proove wise and useful if you did your uttermost best to support HomeKit at least for your existing wifi 6 mesh systems, including those built around rbr850. As many other ...
adhocs
Nov 16, 2020Follower
adhocs wrote:Hello NG. I think it would proove wise and useful if you did your uttermost best to support HomeKit at least for your existing wifi 6 mesh systems, including those built around rbr850. As many other manufacturers with less experience than you release firmwares for their existing mesh kits and Apple is registering more competing products offering HomeKit it would be, as said, wise and about time to offer that support to your customers so that in the future they don't have to rethink again their options regarding flexibility and compatibility of your range. Arnaud D
Thankyou for your input but if you decide to move ahead check that the velop wifi 6 are really supported as mine for exemple three mx5300 are not... they seem to play with people using the triband notion... better check as it is my understanding that still at this moment none of the wifi6 mesh velops systems available to me are supported. Ps after checking still no wireless backbone between the velops and believe me that is a key feature to have!! Arnaud
