I have found that this modem will not use a data and text plan from ATT so I am unable to get a message if it fails over to 4g LTE. Have spent hours with ATT tech swapping plans. Only seems to work w...
phifemira
Jan 24, 2019Fledgling
I have the same issue with ATT. after spending some time on a call today I realize ATT only recongnizes the IMEI of the LB2120 as a data device - ATT says no SMS for a hot spot. So another route for messaging is need or Netgear could instruct ATT to alter the device description with ATT to enable SMS.
