aalexandrebeta's avatar
Jun 03, 2016
Status:
Uncommitted Candidate
sntp router broadcast to LAN
Is it possible to braocast sntp thr the LAN with a router?
Would be a good feature for mangeable switches and other stuffs!
8 Comments
Comments have been turned off for this idea
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Will provide this idea to the management.
    Thank you!
  • ElaineM's avatar
    ElaineM
    Hello,
    Our engineers are asking for more details regarding the setup and would like to see if it's feasible to add it on home routers.
  • for example on my procurve switch they ask for the time config
    SNTP Configuration Enable SNTP
    SNTP/NTP Server       ( X.X.X.X )
    Server Port       ( 1 - 65535 | Default : 123 )
    Time Format
    Last Update
    Attempts
    Last Update Status
    Failures
    for more details just shoot!
  • ElaineM's avatar
    ElaineM
    Per engineering, there's no plan of adding this feature at this time.
  • AbhayB's avatar
    AbhayB
    Status changed:
    Unspecified
    to
  • Sorry got swamped into work did not have time to reply, that feature is easily feasable!
