Is it possible to braocast sntp thr the LAN with a router?
Would be a good feature for mangeable switches and other stuffs!
8 Comments
Sorry got swamped into work did not have time to reply, that feature is easily feasable!
- AbhayBNETGEAR Employee RetiredStatus changed:UnspecifiedtoUncommitted Candidate
That feature would be interresting for security measures for IoT.
OK thanks for the info.
- ElaineMNETGEAR Employee Retired
Per engineering, there's no plan of adding this feature at this time.
for example on my procurve switch they ask for the time config
SNTP Configuration Enable SNTP
SNTP/NTP Server ( X.X.X.X )
Server Port ( 1 - 65535 | Default : 123 )
Time Format
Last Update
Attempts
Last Update Status
Failuresfor more details just shoot!
Hello,
Our engineers are asking for more details regarding the setup and would like to see if it's feasible to add it on home routers.
Will provide this idea to the management.
Thank you!
