Within the Orbi's web admin interface, the ability to sort the attached device list is conspicuously missing, yet very helpful for seeing what is going on at a glance. Most routers have this capacity...
CrimpOn
Mar 07, 2023Guru - Experienced User
Yes, this is correct..... when Access Control is Enabled. Not a major issue, because clicking the Turn on Access Control is not effective until that APPLY button at the top of the screen is selected. Makes it a sort of "multi-step" process:
- Select Advanced Tab.
- WAIT for home page to appear.
- Select Security.
- Select Access Control
- WAIT for device table to appear.
- Mouse over column to sort on... click mouse.
- Nothing happens... oh, yes. select Turn on Access Control
- Mouse over columns again... click mouse.
- Table sorts... and quickly, too.
You are right, also, although sort of hidden (pun), it has been there all along.
