jelabarre59's avatar
Nov 03, 2016
Status:
Unspecified
Sorting "address reservation" listing
Something that would be EXTREMELY useful in the router configuration screen for "Address Reservation" would be a way to sort the list by the various fields.  Right now it lists them by the order you entered them in, which is absolutely useless when you have a lot of entries to put in, and you want to check what you've done already.
I would actually prefer a way I could set ALL of my served addresses in a batch file, rather than having to do them one at a time in the Web GUI.  I used to be able to do that in my (dearly departed) DD-WRT router.
2 Comments
Comments have been turned off for this idea
  • Just looked at the configuration screens for a Nighthawk R7000.   ****STILL**** can't sort by IP number, and the listing ***STILL*** displays by order entered.  Is it really that hard to either automatically sort, or to provide a sorting option?
    This would be significantly easier if I could simply import a CSV or XML file with the pre-assigned addresses, but I'm not holding out any hope for that.
