I need complete turn off the 5G Hz signal power as I alerge to the 5GHz high frequency signal. the 5G Hz signal made me headache. I called customer suppot and they said it is no way todisable the 5G...
Feb 15, 2022Guru - Experienced User
What router do you have?
Some do have the option to disable 5ghz. Others don't (mesh systems)
And some you can adjust the broadcast strength.
