Anyone else think that Netgear should up the encryption and authentication protocols on the OpenVPN utility. I mean come on SHA1 is getting a bit old now right? Also some of the paranoid among us (me...
michaelkenward
Nov 28, 2018Guru - Experienced User
Netgear started rolling this out months ago.
Here's just one:
R7000 Firmware Version 1.0.9.32 | Answer | NETGEAR Support
New Features and Enhancements:
OpenVPN cert update (from MD5 to SHA256)
There have been several firmware updates for the R7000 since then.
If it isn't available on your device, maybe it is seriously old. Or you may mean something else.
