Anyone else think that Netgear should up the encryption and authentication protocols on the OpenVPN utility. I mean come on SHA1 is getting a bit old now right? Also some of the paranoid among us (me...
jamieblack78
Nov 28, 2018Aspirant
Possibly, I have an R8000. Don't think they are that old are they? michaelkenward
EDIT:
When you actually use the VPN it outputs:
cipher AES-128-CBC,auth SHA1
However you are correct, it does have an SHA256 certificate?
