Netgear usb controll center does not work!!! When there will be an update for OSX El Captan????
regnerchaves
Jan 11, 2018Novice
I am running High Sierra os 10.13.2. Using the new NETGEAR USB Control Center 2.40, but same error of 2.36 version, get a message that says that it is not installed completely and should be re-installed. Multiple attemps to no avail. Please, any solution?!?! It's works very well for Windows System, but not in mac High Sierra! Thank you ver much!
