Netgear usb controll center does not work!!! When there will be an update for OSX El Captan????
marcworld
Nov 01, 2015Novice
Same problem here. It is infuriating. FWIW, I can connect to the printer that is attached to my router just fine. Even from my El Capitan Mac that shows this persistent and annoying "Installation is incomplete!" bug, I can actually still print fine.
NETGEAR WHEN YOU ARE GOING TO FIX THIS?
WHATEVER ANSWER YOU HAVE TO OFFER - IT'S NOT FAST ENOUGH.
