EJBsf's avatar
EJBsf
Star
Aug 26, 2015
Status:
Not a Feature or Product Idea
USB Control Center does NOT automatically connect printer
Every time I turn on the computer or wake it up from sleep/hibernation, I have to dig up the Netgear USB control center, open it, click on my printer and then select connect. Windows 7/64.
There should be the option to have the printer automatically connect; it's a timewaster to have to dig out the CC software, launch and connect the printer every time its needed.
I'm likely to stop using the USB CC until this "feature" is fixed.
Thanks.
11 Comments
Comments have been turned off for this idea
