Hi it would be exceptionally helpful if there could be some more verbose debug output for clients connecting/disconnecting to AP’s (both router and satellites) that indicate better troubleshoot i...
Dec 27, 2024Guru - Experienced User
Can try to capture debug logs and unpack the .zip file and check the files out. Many different things happening in the logs there.
