I have just bought the BE18000 Wi-Fi 7 router (RS600) and have come to realize that you cannot do VLAN Tagging on the WAN. I have already read through the thread https://community.netgear.com/t5/...
Feb 17, 2025Guru - Experienced User
Check the
"This article applies to:" For what is supported on the router with features.
If ISPs require a VLAN, some may require the use of there equipment.
I show my RS600 having VLAN support options under the Internet section of the UI which would be part of the WAN side:
You would need to check with the ISP to see if this section can be configured for an ISP use.
