I have a VPN client that I would like to use in Netgear Genie. The only VPN client you can use is PureVPN.
Is it possible to adjust the software from Netgear genie for the users? I would like to choose multiple VPN clients. I am now with another VPN client than PureVPN and this function in Netgear Genie I can not use because the only option is for PureVPN.
2 Comments
Comments have been turned off for this idea
- PirateGeeInitiate
Same question with the RAX80 Nighthawk uses proprietary vpn, I'm like just put in Nord settings but that was not possible. $350 bucks ya think it would huh?
Is it possible to adjust the software from Netgear genie for the users? I would like to choose multiple VPN clients. I am now with another VPN client than PureVPN and this function in Netgear Genie I can not use because the only option is for PureVPN. - River21Novice
I have the same question and would like to be able to use my two 500$ routers to support any VPN uploaded to it, or at least maybe a moderator could explain why not/ as far as I am concerned Netgear is taking money to provide a proprietary VPN which is actually quite bad. NO one I have ever met or know of uses Pure VPN it is a poor product
