secureWannaB
Mar 03, 2017Tutor
Status:
Reviewed
VPN improvements: Stronger encryption and multi-user authentication
1. Looks like it's using SHA1 which is obsolete: Fri Mar 3 07:54:22 2017 us=826132 Data Channel Encrypt: Cipher 'AES-128-CBC' initialized with 128 bit key
Fri Mar 3 07:54:22 2017 us=826220 Data...
Nadicek
Feb 15, 2019Tutor
Definetely makes sence! It would be a lovely feature which would ease use of OpenVPN on the Netgear routers I guess ASUS already has it available in the GUI (I guess it can be made easily available even on Netgear devices, since it is running Linux anyways, but GUI webpage needs to developed and linked with the Linux utilities....).
I would be quite happy with this feature subset (on r6400v2 :) :) )
- feature to upload certificates/keys for the router/VPN from GUI
- feature to upload and manage certificates and keys for the clients from GUI
**** OPTIONAL **** certificate/key generation on the router (somebody/?most folks? would anyways use 3rd party generated certs/key, so certificate/key generation on device would not help them such)
Fingers crossed and Cheers
