It would be great to have a wall mount bracket for the Orbi router. My previous two wifi routers mounted on the wall.
William10a
Feb 02, 2017Master
They also be in designer colors as well to fit in your home just content any metal elements in the colored finish. With a couple of mount holes in a plastic vented outer case. With a vacuum form machine and a wooden form with holes in it for the vacuum table a person cold make a holder.
