It would be great to have a wall mount bracket for the Orbi router. My previous two wifi routers mounted on the wall.
DaveInBurlingam
Mar 04, 2017Novice
I've had my Apple Airport mounted on the wall for years. I currently have the Orbi mounted using the mount used for the last generation of the Airport. Even though the hardware is not similarly shaped, the cables keep it on the mount (I'm using all 4 Ethernet ports on the router, so that gives it stability).
It would be nice to have a mount made specifically for the Orbi though!
