Please implement a wireless scheduler, whereby wireless access can be turned on or off at certain times. I bought and installed a new Orbi system today and was shocked to see that this isn't availab...
Rtm2000
Mar 25, 2020Novice
Yall were over thinking it. Just set the scheduler to disable the radios. Who cares if the sats lose timing ... they will check in and if they cant peer, they can check every 5 min. The sats still have power and a 24 hour timer wont lose time. If they lose power, then tell the base router to build the mesh, set the timer and then go back to sleep. Still better than never getting the feature. :)
May resort to the old RF blocking router blanket :/
