Please implement a wireless scheduler, whereby wireless access can be turned on or off at certain times. I bought and installed a new Orbi system today and was shocked to see that this isn't availab...
Einrich
May 02, 2021Star
Hi Schumaku Guru J.
Based on your explanations, the only option I see would be this -->
A : the router verifies that all satellites have the same time dates etc. They are synced.
B : if so, then the following option becomes available : sleep mode no wifi, no backhaul, no app until target uptime is set at which point all machines go into awake mode (independently) and try to sync again.
Obviously if someone needs the internet during that the offline period, ex security camera, nothing would work. Even trying to manually fix it with app (unless sleep mode leaves a 25% signal alive) would be impossible. If for some reasons the calendars desync, this solution would fail.
So yes, based on your technical explanations I now see your point.
The option would also require a lot of legal caveats before being turned on because some in the general public wouldn t understand. Feature could potentially lead to machines being wrongly returned as faulty.
Well if we can't have the above, can we at least get a client vpn update as well as a decent firewall. J
