There appears to be no way to lock out WPS. To allow or disallow WPS should be an admin permission. Anyone with access to the physical box could create a security risk. Visitors, cleaning personnel, ...
RNASguy
Apr 07, 2019Luminary
Hi michaelkenward,
Thanks for you help. OOooppppsss, off course one would need hardware ID, my mistake.
Nighthawk X4S AC2600 4x4 DualBand Smart Wifi Router R7800
running firmware v1.0.2.62
I don't know if there are any hardware iterations for the R7800, but nothing on the box, case, or docs indicate a hardware version.
RE: your other points:
>> That is also already there in most devices. Isn't that in Access Control on your device?
No it is not. See attached:
>> .... but many Netgear boxes have a setting to disable WPS.
No, WPS cannot be locked out, with admin priviledge only. There is a switch on the router case, so if you have physical access to the router case you have access to the WAN WiFi. One can auto disable WPS PIN after x number of failed attempts, which I have set to "1" but it would be cleaner if the admin could just say NO to WPS.
bc
