- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Info aircard AC810-100EUS CAT 11 and 256QAM
- Mark as New
- Bookmark
- Subscribe
- Permalink
HI , the AC810-100EUS , have lte cat11 and 256 qam ? thanks 😉 if not , is possibile to unlock via firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Info aircard AC810-100EUS CAT 11 and 256QAM
Hi,
Yes, the AC810-100EUS supports 4G LTE Cat 11 and 256QAM.
You don't need to do any operations with router firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
thanks , how check if my support 256qam? i live in sanremo and tim perhaps have 256qam , but nothing go = s7 edge have cat 9 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can't do it without special software - QUALCOMM eXtensible Diagnostic Monitor. It costs more than a thousand dollars.
Or you can check it from Base Station side, if you working on mobile network operator.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks this info 256qam
have tested modem AC810-100EUS ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, it is. Only after verifying it was possible to make sure that everything works. I think Netgear (Sierra Wireless) makes the best LTE routers for now, because of using Qualcomm chipsets. Pretty good quality deviсes.
Only one problem - no 2G(GSM/EDGE).
