3 Second Look back work on Wireless?
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello.
I have some Arlo Pro 1 cameras and am happy with them (except for some nightvision issues I am experiencing related to wet/cold) and was thinking of adding a Pro 2 to the network. I am concerned about the Pro 2 nightvision issues that I am reading about on the forums, but am tentatively still willing to get one. However, one of the main features that I want from the Pro2 is the 3 second look back on motion videos etc... does that work when the camera is on battery power, or does it have to be plugged in for that feature? How exactly does it work? I am imaging it where for example, my camera is triggered by a rabbit running across the yard. Normally the camera cuts in after the rabbit has taken a couple of hops into the frame already. My imagination says that the 3 second buffer would basically grab those first few hops. Is this true?
- Related Labels:
Before You Buy
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
is the 3 second look back on motion videos etc...does that work when the camera is on battery power, or does it have to be plugged in for that feature?
Yes..... the 3 second look back is ONLY functional when on ac power. ( the camera is always streaming and adds the 3 seconds to the front end of the triggered recording )
When on batteries, the Pro2 is more like a Pro ... so if running on batteries there , IMO, no real advantage of the Pro2
Morse is faster than texting!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
1. Battery in camera and usb power adapter connected.?
2. Battery NOT in camera and usb power adapter connected?
I’m running on option 1 abowe and look back is not working. Do you really need to remove the battery to get it running?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
No. As long as the camera is using AC power the look-back feature should work. Watch a video carefully - you should see it start and then see the motion that activated the recording. It may be subtle. Post a video link if you need us to look.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Ok I did more testing under controlled circumstances. 3 sec look back works with the battery in the camera and the USB AC adapter plugged in. I can also confirm it does not matter which cable and USB adatoer you use. In my tests I used a Samsung AC adapter and a micro USB cable from another device.
3 sec look back works:
Running only on AC:
Running on battery and AC:
3 sec look back does not work:
only running on battery:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The power supply can make a difference depending on the supply as well as the camera model. In general, the cameras are designed around 5v to run the camera and 9v to charge. I suspect your Samsung supply is a 5v/9v one so should work with no issues. I think it's the Pro 2 cameras that will work and charge (slowly) off a 5v supply but the Pro cameras will not, apparently needing a slightly higher 5v output (5.2v-ish). I may have that backwards but that's the general idea.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Arlo Mobile App
499 -
Arlo Pro 2
11 -
Arlo Smart
152 -
Before You Buy
957 -
Firmware Release Notes
57 -
Google Assistant
1 -
IFTTT (If This Then That)
24 -
Installation
1,102 -
Online and Mobile Apps
865 -
Service and Storage
317 -
SmartThings
37 -
Troubleshooting
5,945
