- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
If you have this base station (VMB 4000) don't remove the device from your app, as there is a known issue that will not allow you to re-add it. Support is aware of it and said their Engineers are working on it, but couldn't give me a time frame. Based off that alone, I'm going to need to replace these camera's ASAP with another solution. I can't go days without home security cameras.
This base station came as a kit with 2 Arlo Pro 2 cameras, which are going EOL 1/1/25 - but the base station isn't going EOL. I just don't see them fixing this any time soon, forcing me into an upgrade or replacing the solution with another option.
The support case for anyone's reference is Arlo case #44038188
Solved! Go to Solution.
- Related Labels:
Arlo Mobile App
Before You Buy
Installation
Troubleshooting
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @cas42021
I have escalated this for you and support will be reaching out to you as soon as possible.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @cas42021
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @ShayneS
Thanks for the help, but the only 2 times I heard from support in the last 52hrs was to tell me they still don't have a resolution and will update me once they do. No details, no anything. I tried to escalate, ask to speak with someone, it's not possible. I was told a Manager would call me back. I provided my contact number and gave 24x7 availability. I'm still waiting by the phone. When pressed, I asked them of the other customers affected, what's the date of the first report? They told me April 15, 2024. That's 2.5 weeks ago, insane. Still no resolution.
Who thinks it's acceptable to go 2.5 weeks without home security cameras? Support is lacking to say the least. I hope they do the right thing here, eventually..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It took 9 days but Arlo Support sent me a new VMB4500 Pro Base Station, and so far so good. Appreciate the help.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@cas42021 Thank you for the update, please let me know if you need any further assistance and I will be here to help out.
Arlo Mobile App
499 -
Arlo Pro 2
11 -
Arlo Smart
152 -
Before You Buy
957 -
Firmware Release Notes
57 -
Google Assistant
1 -
IFTTT (If This Then That)
24 -
Installation
1,102 -
Online and Mobile Apps
865 -
Service and Storage
317 -
SmartThings
37 -
Troubleshooting
5,945
