Arlo Pro 2 Base Station Offline
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Here is my issue out the blue 1out of 6 cameras went offline, I've re-synced it numerous times and after 10-15 minutes it drops out. I've switched the battery out with 2 other cameras no change. The other thing I noticed is the only way to get the camera to cycle on off is when you pull the battery out opening and closing the cover doesn't cycle the LED lights. Lastly I am able to keep it synced as long as I have it plugged into the charger, but this is no good to me since its located outdoors. My system is 4 months old and never had a problem, any suggestions on what is wrong with camera?
- Related Labels:
Troubleshooting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Swap cameras around to see if it's the camera or the location.
Opening and closing the battery door does nothing since there's no battery contacts on it unlike the original wireless cameras. Reinserting the battery is the only way to break/make the connections.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks for the reply I did what you suggested trying a different location even closer to the base station and still have the same problem. I'm thinking its a camera issue because when it goes offline the red LED's don't even come on even when you walk or swipe your hand across it to activate it by motion almost as if its totally dead. It works for a very short time after taking battery out and then back in.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
If you're sure the battery is charged, open a case with support:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Yes I'm sure the battery is fully charged, I'll open up a case with support thanks.
Arlo Mobile App
499 -
Arlo Pro 2
11 -
Arlo Smart
152 -
Before You Buy
957 -
Firmware Release Notes
57 -
Google Assistant
1 -
IFTTT (If This Then That)
24 -
Installation
1,102 -
Online and Mobile Apps
865 -
Service and Storage
317 -
SmartThings
37 -
Troubleshooting
5,945
