Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Arlo Pro 2 Clicking Noise
Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi, please can anyone help. Iv just purchased the Arlo Pro 2 4 pack camera pack from amazon. Initially all was fine, but after around 5 days I can now hear a background noise which sounds a bit like a ticking noise followed by a croaking type noise. Has anyone had this issue and if so is there a fix for this? Thanks allot.
10 REPLIES 10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Can you post an example?
Make a manual recording, then from the library, select the options for the recording, click on share and choose copy link, paste into your post. Link lasts a day only.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thank you for replying, the link is below. It sounds like a croaking noise for reference, there is a chime type noise but that’s actually a wind chime, the croaking is the undertone.
Thanks again.
https://arlo.netgear.com/hmsweb/users/library/share/link/D70F981A4A39056E_201904
Thanks again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
A bit hard for me to hear it, does it sound more like running water in a stream?
Is the camera externally powered or just battery?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thank you for looking at it. It sounds like a clicking noise finishing with a croaking type noise then repeats. And they are all wireless powered by battery.
Thanks allot.
Thanks allot.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
And further to my last I’ll try get you some better footage during the day so you can hear it properly.
Thanks again.
Thanks again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Do you get the noise while live viewing the camera as well as the recording?
Also download the recording to a PC and see if the issue is the same. It might be the audio decoder being used.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Does it sound similar to this recording?
https://arlo.netgear.com/hmsweb/users/library/share/link/BB14C3F7C4E8310E_201904
The noise of a repeated frog or cricket in background.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi,
It sounds exactly like that! It’s exactly the same, with the croaking backing tone.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I get the croaking on only one battery camera, the other is more like a waterfall. The two powered cameras I have just have ticking.
If I was asked to speculate I would say that it is poor power supply rail decoupling design between the video and audio circuits in the camera.
To be practical it is likely to be drowned out by the wanted noise when it occurs as a function of the microphone auto level control.
So to conclude, yes others have the noise your getting and the only fix will likely be via support.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
That’s great, you have been fantastic thank you. Nice to know these forums are worth while and people actually know what they are talking about.
Thanks again and all the best.
Related Labels
Arlo Mobile App
499 -
Arlo Pro 2
11 -
Arlo Smart
152 -
Before You Buy
957 -
Firmware Release Notes
57 -
Google Assistant
1 -
IFTTT (If This Then That)
24 -
Installation
1,102 -
Online and Mobile Apps
865 -
Service and Storage
317 -
SmartThings
37 -
Troubleshooting
5,945
