Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Android 7 Nougat not compatible
Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Retired_Member
Not applicable
2017-11-21
08:05 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
For the two way audio the sound going to the camera breaks up and cuts out after part of the first word. Arlo support said it will be my phone thats the issue....it is but only due to it running android nougat.
Works on another android 4 kit kat phone and my laptop, just not on android 7 nougat
On looking at the app settings it stated the app is designed for a previous android version...
Can arlo confirm that they are going to update the app as android 8 is also out.
Ive had my phone for over a year and would have expected the app to be updated by now.
Labels:
- Related Labels:
Troubleshooting
5 REPLIES 5
Retired_Member
Not applicable
2017-11-21
08:27 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
P.s. it works when using earphones with microphone.
Can arlo shed any light on if this is a known issue and if a fix is being worked on?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
report it to Netgear Support and see if they know about it... if not, they can't fix it without knowing... a win-win for all
Morse is faster than texting!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
A major Android OS and they are unaware, relying on users to report it? That implies incompetence and/or indifference.
Retired_Member
Not applicable
2017-11-22
04:44 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I did contact netgear but they couldnt help me over chat. I suggested they could look into if the app needs updating for android 7 but they didnt suggest that they will look into the issue.
I gatheted from the conversation that they were implying I should use an older android os phone.
Can netgear respond with anything more positive regarding the above?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have 3 devices using Android 7.x - the app works perfectly on all. It would be painful but it may be that you need to factory reset the phone since it seems to be a local problem with your device.
Related Labels
Apple HomeKit
1 -
Arlo Mobile App
312 -
Arlo Pro
27 -
Arlo Pro 2
1 -
Arlo Pro 3
2 -
Arlo Secure
1 -
Arlo Smart
72 -
Arlo Ultra
1 -
Arlo Web and Mobile Apps
6 -
Arlo Wire-Free
10 -
Before You Buy
1,171 -
Discovery
1 -
Firmware
1 -
Firmware Release Notes
119 -
Hardware
2 -
IFTTT
1 -
IFTTT (If This Then That)
48 -
Installation
1,382 -
Installation & Upgrade
1 -
Online and Mobile Apps
1,266 -
Partner Integrations
1 -
Security
1 -
Service and Storage
563 -
Smart Subscription
1 -
SmartThings
39 -
Software & Apps
1 -
Troubleshooting
7,018 -
Videos
1
- « Previous
- Next »
