- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Just got my new Arlo Pro yesterday and noticed that the magnet seems to be weak or the battery might be heavier as it keeps slipping or moving down on the mount and does not hold position. Anyone else notice this or have this problem?
twice I have set it up and it seems it just slips down, does not fall off but does not stay in position. It is a bit heavier than the first generation arlo and wonder if that is the reason.
Solved! Go to Solution.
- Related Labels:
Installation
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thank you to all community members for bringing this to our attention, if you are using the wall mount that came with your Arlo Pro system and your camera is still not staying in position, contact Arlo Support to speak to an expert for further investigation of the issue. You will find several options for contacting support in the provided link. If you have any additional questions/concerns feel free to private message me. I would be happy to help.
For those affected by this issue, please take a look at this article: My Arlo Pro Wire-Free camera is losing its position; what do I do?
JamesC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Please if so, let Netgear know... you may not be the only one.
But, to make sure, have you used the newer "half - ball" mounts .. as the newer have a grainy surface compare to older ones ( I think came from vuezone )..
A trick that may work in the meanwhile ( i did it with some of the older mounts ) was use a dime shaped piece of old balloon material ( just soft rubber that's thin ) between the cam and the ball mount.... solved slippage.
Morse is faster than texting!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Yes I did call Netgear Support today and first call after 20 minutes dropped and no one called back and than on the 2nd call after explaining and the agent going back and forth was told someone will be calling back within the day to see what the resolution or issue is.
All camers are doing this as left them again in correct positon and than they are all losing position again. And i have used the new mounts that came in the box.
So when you say the trick to use, can you explain a bit further as atleast might help meantime to keep the in position as as of right not they are unuseable.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks for the further info...
Not sure why you have problems... I just tested a half-ball mount and a lollipop mount (with full ball)... found that on my PRO it was fine and no slippage even with shaking... Question , where is it mounted? Users have seen problems with small birds landin on the cameras at times.
Or possible that something can hit it ?
As to the temp fix, I took an old balloon, cut a dime size piece of rubber from it... Then placed it on the mount and put the camera over it. The small piece provided just enough more friction/sticky to stop the cams from sliding.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2 are outside and 1 inside. They just loose positon in a few hours as gradually sink, when first mount themk in position they seem solid but do gradually sink. Have had the first generation too and never this issue.
Will use the balloon trick for now. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
your not alone... Jeff sees similar problem
https://community.netgear.com/t5/Arlo-Pro/Pro-cameras-update/m-p/1157420
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
This looks as if this may be an issue.
Please everyone who already have the Pro, bring all the issues up, nothing is too small to bring up, Netgear needs to be aware and hopefully production models can be corrected!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
That is good to know, as it definitely is a slip issue due to the weight of the camera being different as mentioned in the other post.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Good afternoon Arlo Community!
@RobertRosal - You are absolutely right! Nothing is too small to bring up! This is a perfect example of how NETGEAR can gain insight into product issues and get them corrected! This issue has been raised to our engineering team to investigate further!!
@dane - We are also investigating a possible telecomm issue so thank you for bringing that to our attention! I'll take this issue offline with you so as not to clutter this thread. If support hasn't already issued an RMA please let me know and I'll follow up accordingly.
@TomMac - Thank you for always thinking outside the box and sharing your ingenious ideas and work-arounds!
Thank you one and all for adding immense value to this community!
ChristineT
Community Manager
____
Please click KUDOS or REPLY if you found this helpful.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
To ChristineT
I did contact support twice but no RMA has been issued and not sure if a case opened as yet as not recieved any email with a case number or anything. How do I get in otuch with you to open RMA..
thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
To ChristineT
thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thank you,
JamesC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
As Nassim above mentioned, we are using the new mounts that came with the Arlo pro Camera and they are not staying in place. This really needs to be corrected rather than saying we are using wrong mounts.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It's not really an issue of telling you that you're using the wrong mounts, it's a possibility. I did try to use the old mounts first and then switched to the new ones. I can't tell a difference between them so if there's a difference, it's not obvious.
In any event, if it's slipping for you like mine are, contact support, as stated in the FAQ and here.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I am having the same prolem.
I have 3 cameras on the half ball wall mount, in a 12 hour time all 3 will move down a noteable amount. 1 camera will move from approx middle posion to all the way down, the other 2 are creeping slower but will need adjusted in the morning
This is my 1st Arlo system, is not an old mount issue, i have no old mounts
*edited for typos 😞
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
They look the same to me.
I am asking this because I am selling my older original Arlo kit but didn't swap the mounts since they are already mounted on my walls... should I swap these mounts to the new ones? (The old ones seem to be working fine)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I can't tell the difference, either. Maybe a very close inspection of the surface may tell but I had the Pro camera slip in exactly the same way with both old and new mounts.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I am going to buy some balloon's today and try the piece of rubber idea .... I do not think the problem is a "weak magnet" I think it is poor friction
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have been talking to Netgear support on this issue and am having some new wall mounts sent to me ... I am yet to receive the mounts to report any differences, but the communication with them was very easy ... I encourage people who are having an issue to contact support directly, I used Live Chat and was a godo experience
Apple HomeKit
1 -
Arlo Mobile App
318 -
Arlo Pro
27 -
Arlo Pro 2
1 -
Arlo Pro 3
2 -
Arlo Secure
1 -
Arlo Smart
75 -
Arlo Ultra
1 -
Arlo Web and Mobile Apps
6 -
Arlo Wire-Free
10 -
Before You Buy
1,175 -
Discovery
1 -
Firmware
1 -
Firmware Release Notes
119 -
Hardware
2 -
IFTTT
1 -
IFTTT (If This Then That)
48 -
Installation
1,383 -
Installation & Upgrade
1 -
Online and Mobile Apps
1,266 -
Partner Integrations
1 -
Security
1 -
Service and Storage
563 -
Smart Subscription
1 -
SmartThings
39 -
Software & Apps
1 -
Troubleshooting
7,047 -
Videos
1
- « Previous
- Next »
