Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Arlo Pro white solar charger
Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Everyone,
Few quick questions:
Does anyone know of a white solar charger that works with the Arlo Pro cameras?
Can I use another (non Arlo brand) solar charger? If so, what specifications should I look for?
Thanks,
Brian
Labels:
- Related Labels:
Before You Buy
2 REPLIES 2
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
No white panel TMK, ... also I do believe you are stuck with the Arlo solar panel as the seal for the usb port is a bit different than most ( not to mention the voltage specs are pretty tight ).
Anything else and if water gets in, your on your own as Netgear prob will not warranty with 3rd party items
Morse is faster than texting!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks.. A white panel would be great. Anyone know if that’s in the works?
Related Labels
Apple HomeKit
1 -
Arlo Mobile App
315 -
Arlo Pro
27 -
Arlo Pro 2
1 -
Arlo Pro 3
2 -
Arlo Secure
1 -
Arlo Smart
74 -
Arlo Ultra
1 -
Arlo Web and Mobile Apps
6 -
Arlo Wire-Free
10 -
Before You Buy
1,173 -
Discovery
1 -
Firmware
1 -
Firmware Release Notes
119 -
Hardware
2 -
IFTTT
1 -
IFTTT (If This Then That)
48 -
Installation
1,382 -
Installation & Upgrade
1 -
Online and Mobile Apps
1,266 -
Partner Integrations
1 -
Security
1 -
Service and Storage
563 -
Smart Subscription
1 -
SmartThings
39 -
Software & Apps
1 -
Troubleshooting
7,037 -
Videos
1
- « Previous
- Next »
