- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello,
I have a Blueiris system installed and I wanted to add Arlo Pro camera (without the base station).
I love your Arlo pro features and the ability to hang it on the wall without all the cabling.
my question is simple - can i connect the camera to a local computer via Wifi and not the base station, allowing me to connect it to my working software?
Will it work with Blueiris for the best knowledge you have?
Solved! Go to Solution.
- Related Labels:
Before You Buy
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The Arlo and Arlo Pro cameras MUST use the base... if you want to hook directly to your home wifi, then there is the Q camera ( tho it is indoor rated only )
It prob will not work with Blueiris unless you rig up some form of IFTTT
Morse is faster than texting!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
For the good of all, this is the answer I recieved from BlueIris:
"The Arlo camera is a cloud-only camera I believe, and is not designed to be used with 3rd party applications, so I do not believe it will be compatible with Blue Iris."
Apple HomeKit
1 -
Arlo Mobile App
312 -
Arlo Pro
27 -
Arlo Pro 2
1 -
Arlo Pro 3
2 -
Arlo Secure
1 -
Arlo Smart
72 -
Arlo Ultra
1 -
Arlo Web and Mobile Apps
6 -
Arlo Wire-Free
10 -
Before You Buy
1,171 -
Discovery
1 -
Firmware
1 -
Firmware Release Notes
119 -
Hardware
2 -
IFTTT
1 -
IFTTT (If This Then That)
48 -
Installation
1,382 -
Installation & Upgrade
1 -
Online and Mobile Apps
1,266 -
Partner Integrations
1 -
Security
1 -
Service and Storage
563 -
Smart Subscription
1 -
SmartThings
39 -
Software & Apps
1 -
Troubleshooting
7,019 -
Videos
1
- « Previous
- Next »
