My Arlo Pro Battery Is Not Charging
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
My arlo pro battery will not charge and the camera keeps disconnecting. It remains at 2-3 percent, even after charging for 5+ hours with the correct charger. I have removed the battery, turned off the camera, put the battery back in, and plugged the cord in, and nothing. It will temporarily blink blue, flash once orange, then stops blinking. Does not show the camera as charging in the app either. App/camera updated prior to posting this.
- Related Labels:
Troubleshooting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Are you using the supplied USB cable?
Flashing blue briefly means that the correct charger has been attached.
I think that an orange flash means the battery is flat, which you know already.
If you have a second camera have you tried swapping batteries and cameras around?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Got the same problem! New Arlo pro, first time trying to charge. Lasted a month or so outside, now down to 1%, just stays off-line. Can't get it to charge at all using the Arlo charger and cord.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
When you have the camera on charge, what does the app. report?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
When you have the camera on charge, what does the app. report? Does it show that the camera is charging and is the % increasing over time?
It's unlikely that 3 battery/camera combos are faulty. It's possible that there is a problem with the charger or the USB cable.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Pop the battery out and reinsert. If you have another camera with a good battery, try swapping them around. Otherwise, open a case with support.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It was the charger for me. If you have a good one, use that one to charge all the batteries. Seems to be really high infant mortality for those chargers.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
tamarastokes,
Are you using the charging cable and ac adapter that came with your Arlo Pro kit?
JamesC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Have you checked for charging progress in the app/web using Settings, My Devices, your camera? The battery display should update as it charges (I find I have to refresh the page to get it to update). The camera itself has no indication that it's charging other than the initital blue LED indicating that the charger is connected. If the setting for the camera is to turn the LED on when it's finished charging, the camera LED will turn solid blue when it's done. Charging should take about 2.5 hours max.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thank You for the response. It's def. not working.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
yes checked thru app that charging was taking place. I have 2 chargers and one of them is not any good. This upsets me as they are both brand new!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Well, replace it. You always have the choice of swapping at the store or opening a case with suport here to do that.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Or just open a case with support here.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Nobody ever said you need the original packaging unless you're returning it to a store for refund or exchange. Receipts are always needed to receive warranty work.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I would like for Netgear to replace the charger that is not working without having to go bacl to the store to replace it!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Then you would need to contact support and open a case with them.
Apple HomeKit
1 -
Arlo Mobile App
316 -
Arlo Pro
27 -
Arlo Pro 2
1 -
Arlo Pro 3
2 -
Arlo Secure
1 -
Arlo Smart
75 -
Arlo Ultra
1 -
Arlo Web and Mobile Apps
6 -
Arlo Wire-Free
10 -
Before You Buy
1,174 -
Discovery
1 -
Firmware
1 -
Firmware Release Notes
119 -
Hardware
2 -
IFTTT
1 -
IFTTT (If This Then That)
48 -
Installation
1,382 -
Installation & Upgrade
1 -
Online and Mobile Apps
1,266 -
Partner Integrations
1 -
Security
1 -
Service and Storage
563 -
Smart Subscription
1 -
SmartThings
39 -
Software & Apps
1 -
Troubleshooting
7,042 -
Videos
1
- « Previous
- Next »
