- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I just bought my sencond Arlo camera. I upgraded from the regular Arlo Wireless to Arlo Pro. I'm very dissapointed with the new camera. The battery won't last more than 48 hrs. and it doesn't detect motion at all.
My wifi have all the bars with very good speed.
Arlo base it within about 5 feets distance.
It worked only for about two days.
I have to mention that my old arlo is working perfectly.
I tried so many things and nothing works. The strange thing is that it worked for two days and stopped without me making any changes.
HELP!
Solved! Go to Solution.
- Related Labels:
Before You Buy
Troubleshooting
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
JamesC wrote:gamoneda03,
Consider removing the camera from Settings > My Devices and go through the sync process again. Do you still see the same behavior?
Another way to isolate the issue further is to move another Arlo Pro camera that is behaving normally to the same location as the problem camera. This will help identify if the location is causing an issue.
JamesC
Yes, I actually did all that and nothing worked. The only way to solve the problem was to return the camera to BestBuy and get a replacement. I only had it for two weeks. The replacement work perfectly!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It could be various things including a bad battery or bad camera. Is the cmera in the exact same location?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
No, I moved the camera to different locations already. All the locations are with a very close range to wifi. I might have to ask for a replacement. Is not just the battery dying so fast, but also it doesn't detect movement but it does detect audio. Very weird.
I'm so happy with my old Arlo wireless. No issues with that one at all.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
gamoneda03,
Are you using the default "Armed" mode or a custom mode? How many detection events are you getting daily?
JamesC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
JamesC
Hi James,
I'm using the default "Armed" mode. I'm getting like one or two audio detections per day because of the train passing by in the morning, but zero movement detection. I tried arming the camera and make a dance if front to short and far distance and still it doesn't detect anything.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
gamoneda03,
JamesC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
JamesC
Apple HomeKit
1 -
Arlo Mobile App
313 -
Arlo Pro
27 -
Arlo Pro 2
1 -
Arlo Pro 3
2 -
Arlo Secure
1 -
Arlo Smart
74 -
Arlo Ultra
1 -
Arlo Web and Mobile Apps
6 -
Arlo Wire-Free
10 -
Before You Buy
1,171 -
Discovery
1 -
Firmware
1 -
Firmware Release Notes
119 -
Hardware
2 -
IFTTT
1 -
IFTTT (If This Then That)
48 -
Installation
1,382 -
Installation & Upgrade
1 -
Online and Mobile Apps
1,266 -
Partner Integrations
1 -
Security
1 -
Service and Storage
563 -
Smart Subscription
1 -
SmartThings
39 -
Software & Apps
1 -
Troubleshooting
7,020 -
Videos
1
- « Previous
- Next »
