Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
When siren turned on comes through base of my arlo pro and not through camera. How do I fix?
Reply
Discussion stats
  • 6 Replies
  • 2924 Views
  • 0 Likes
  • 5 In Conversation
Saab2005
1 ACCEPTED SOLUTION
Accepted Solutions
Streak2
Master Master
Master
That's the way it's supposed to work on the Arlo Pro.
The siren is built into the base.
6 REPLIES 6
Streak2
Master Master
Master
Saab2005
You didnt read the question properly.....yes siren suppose to work on base however siren use to come on camera also,but not anymore only comes through base and not camera.I would like for siren to come through camera, like it did before. How do I make this happen again?
watchdog99
Luminary
Luminary
siren only works through the base. that's how the system is designed.
Saab2005
Youre wrong.During initial installation less than a week ago, alarm when triggered would come through the camera and not the base. Thats what I d like to get back. Not sure if defective or not, but makes more sense to have choice of where alarm would sound in base or camera?
jguerdat
Guru Guru
Guru
The answer provided is absolutely correct.  There is no siren on a Pro camera.  Only the Go camera, which doesn't use a base, has this feature.  The Pro system only has a siren in the base.
superben79
Apprentice
Apprentice
yes, you definitely have a defective system which the siren was coming from the camera.
