Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
ARLO Q und ARLO Pro
Reply
Discussion stats
  • 1 Reply
  • 2468 Views
  • 0 Likes
  • 2 In Conversation
paulrosen
Follower
Follower
can I tape over the blue light so as not to draw attention to the camera without interfering with sound or picture?
1 REPLY 1
TomMac
Guru Guru
Guru
yes, the led does not effect anything if covered.
Also make sure you have turned off the led in settings. the only exception for the led to come on if toggled off ( on the Q ) is if at max range for signal ( it still comes on ) ...I cover the Q led over a year ago due to this
Morse is faster than texting!
Discussion stats
  • 1 Reply
  • 2469 Views
  • 0 Likes
  • 2 In Conversation
