Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
Arlo light USB cover
Reply
Discussion stats
  • 8 Replies
  • 7081 Views
  • 0 Likes
  • 4 In Conversation
Asiyahola
Bought an Arlo light 3 pack with bridge. On every one of the lights the plastic USB cover pops out exposing the connection to the elements. Right now the only way to stop it is to tape it down.
8 REPLIES 8
jguerdat
Guru Guru
Guru
While it's certainly possible that there's a defect, are you taking the time to ensure that you're lining up the cover protrusions on the cover with the openings in the light.
If a true defect, swap at the store or open a case with support here.
Asiyahola
I bought this through Amazon. It's definitely a defect. All 3 lights have the issue with the same defect. How do I open a case?
Thanks,
Brian
JamesC
Community Manager
Community Manager
Asiyahola,
If lined up correctly, the rubber is molded to fit into the USB slot and should not come out on it's own. Be sure everything is lined up when sealing the usb connection with the cover. If you're still having an issue, can you provide a picture of the bottom of the light including the usb cover?
JamesC
jguerdat
Guru Guru
Guru
The fact that all 3 do this makes it rather difficult to believe it's a manufacturing defect but it's possible. I can view the cover as it inserts into the USB port - have you tried that? BTW, is the strap that holds the cover onto the light intact?
Asiyahola
Are you kidding me? If it was only one then it would NOT be a manufacturing defect...the fact that it's 3 of them points directly to it being a manufacturing defect. I will record a video of it popping out on it's own, on all 3. I will post it here and Amazon so everyone can see and know to avoid buying this product.
This customer service is pretty bad!
michaelkenward
Sensei Sensei
Sensei
If all the devices are the same that smells much more like a design defect.
What customer service are you talking about there? If you mean this place, it is not "customer service". It is user-to-user support self forum "manned" by fellow users and with some input from a handful of Arlo employees.
As it says on the front page:
"Learn, explore, ask questions, and connect with our community of customers and experts."
For official support, press the button at the bottom of this screen.
Just another user
Arlo hardware: Q Plus, Pro 2 (X2), Pro 3 (X3), Pro 3 Floodlight, Security Light (X2), Ultra (X2), Doorbell, Chime
Asiyahola
Pressing the button at the bottom takes you right back here. Do you have a phone number or website in order to contact?
Asiyahola
Nevermind, just found it.
Discussion stats
  • 8 Replies
  • 7082 Views
  • 0 Likes
  • 4 In Conversation
