Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have 15 witless Arlo cameras
4 of them are inoperative, with fresh batteries they will not auto sync and will not manually sync using the base station,
2 of them give off line messages . Of these two ,one ( when it was working)
Had a purple hue in the stream not the normal colour. The other two will also not sync the base station green light eventually stops but the blue light continues to slowly flash for ever!
I might add that all these units have been functioning well up until about 9 months ago . Any clues? Yes
Solved! Go to Solution.
Labels:
- Related Labels:
Troubleshooting
1 ACCEPTED SOLUTION
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Try to reboot your base before syncing teh cameras. Unplug base from outlet for about 3 minutes then plug it back. Try syncing the cameras and check if they will sync.
3 REPLIES 3
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
If this doesn't help, punt. Remove all devices from Settings, My Devices. Use the Add Device button on the Devices tab to claim the base. Sync the cameras. Any luck?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Disconnected base station power for a while , was successful in restoring 2 ,
Opened and closed battery compartment and they were recognized within a couple of minutes,
Just have to get more batteries for the other two..
Related Labels
Accessories
4 -
Activity Zones
1 -
Amazon Alexa
1 -
Apple HomeKit
2 -
Apple TV App
9 -
Applications mobile et en ligne
1 -
Apps
4 -
Arlo Go
3 -
Arlo Mobile App
471 -
Arlo Pro
36 -
Arlo Pro 2
1 -
Arlo Q (Plus)
3 -
Arlo Smart
124 -
Arlo Web and Mobile Apps
18 -
Arlo Wire-Free
30 -
base station
1 -
Batteries
529 -
Before You Buy
735 -
Can't view cameras live at all
1 -
Dépannage
1 -
Détection de mouvements
1 -
Fehlerbehebung
1 -
Firmware Release Notes
93 -
Google Assistant
1 -
Hardware
1 -
home security
1 -
IFTTT (If This Then That)
105 -
Installation
1,956 -
Iphone 14 pro
1 -
Live view
1 -
Modes and Rules
1 -
Motion Detection
2 -
Object Recognition
3 -
Online and Mobile Apps
983 -
Online und mobile Apps
1 -
Order Not Going Through... help please!
1 -
Other Discussions
1 -
Partner Integrations
4 -
Security
1 -
Service and Storage
14 -
Smart Subscription
3 -
SmartThings
71 -
Troubleshooting
8,570 -
Videos
233 -
Vidéo
2 -
Warranty & Contracts
2
- « Previous
- Next »
