RogerSYSAd's avatar
RogerSYSAd
Follower
Nov 16, 2023
I have 3 WAX615 and I am trying to configure mesh without Inisight
Hello,
I was wondering if someone could share the settings they used to configure a successful mesh network without using Insight. I understand it comes with a 1 year free subscription. The customer opted to not go that rout.
I have enabled band steering 802.11 k/v. But it still struggles to switch to the closest AP. Normal speeds next to one of the WAX615's are around 300 Mbps for this customer. He was standing next to one and it was 30 Mbps. My guess is it's still trying to access one of the AP's further away.
Any pointers would be much appreciated.
Thanks, Roger
  • schumaku's avatar
    schumaku
    Not aware having spotted this should be feasible at all. All the documentation available eg. with the WAX615 Data Sheet and the Insight Managed WiFi 6 AX3000 Access Point Model WAX615 User Manual does always cover an Insight Instant Mesh - but no manual configuration of such a free Instant Mesh.
    Definitively, if the customer does expect seamless roaming using WPA3-Personal (WPA3-SAE) he needs to understand that this requires either some controller- or cloud-based assistance.
    For my part, I'm buffed people desperately want this considering some cabling and a capable PoE+ switch with 2.5 GbE would provide a much better service. Minimum starting point would be a MS108TUP allowing full Insight management, hardcore network admins might go for a MS108EUP. Last but not least, a dedicated WiFi backhaul offers the best of both worlds with easy setup and great performance, is simple to set-up, and will perform over all of its life time.
    Before your customer does try: No, I'm not Netgear, just an experienced networks and systems admin deploying such networks, some bigger sites like an ice hockey venue for some 2500 people, among bunches of smaller deployments with several hundred WAX6xx and MS510TXUP on a bigger 10 GbE backhaul where required.
    Curious what this RAX43 should do in this customer environment.
  • Hi,
    MESH mode is not supported in standalone mode. AP needs to be managed using Insight for this feature.
    Thanks!
    Pramendra Singh
    NETGEAR SMB Wireless Team
ProSupport for Business
