beezer's avatar
beezer
Apprentice
Apr 27, 2019
WC7500 SSL Certificate is hacked!
(This is actually for the WC7500 but the drop-down won't let me select that)
I have a very strange self-signed SSL cert on my wc7500. I cannot replace it, b/c the system wants something that is not required by wc7500 (controller key)...
How do I generate and upload a new (trustable) SSL CERT on a WC7500?
  • Well, after all this time, the "solution" is that they have a firmware upgrade (6.5.5.18) that provides a *different* self-signed certificate in response to a TLS request.
    You still cannot use PKI.
    The documentation for the WC7500 certificate page still says "This page lets you to add certificates to WC7500." (not English)
    The documentation for the Password field still says "This is the password for WC7500 Certificates" (certificates don't have passwords)
    The documentation for the Controller Key field still says "Enter the Controller Key", etc. (not even slightly helpful)
    If you tell it to boot or update "now" it schedules it for some time in the future or past, depending on your current offset from GMT.
    This firmware is such a hack on its surface it is impossible to trust that it is appropriate, in terms of security, reliability, or functionality, to use in any professional environment.
    • beezer's avatar
      beezer
      Apprentice
      Apparently the graphic doesn't show in my post. If not hacked, at least suspicious and no way I can trust it:
      E = [email protected]
      CN = Dexter
      OU = Engineering
      O = Firetide Inc.
      L = Bangalore
      S = Karnataka
      C = IN
      I tried a PEM with just the private key for the Controller Key and it won't validate  (Validation of Controller Key/Cert/CA Cert failed).
      • schumaku's avatar
        schumaku
        Stick to 2048 bits, nothing "exotic" like EC and the like, and upload all three.
ProSupport for Business
