Tepasquan
Jul 05, 2017Aspirant
WC7500 wireless controller
Hello ,
This is the gear I have.
A WC7500 wireless controller, NETGEAR GS724T v3 ProSAFE 24-port Gigabit Smart Switch, NETGEAR ProSAFE GS510TP 8-Port Gigabit PoE+ Smart Managed Switch with 3 WND930 AP's and a Nighthawk AC1900.
There will be multiple TV streaming, not more than 20 at max, via ethernet with the wifi for office and guest devise usage.
This is my first adventure with ProSAFE. Would like to find some basic "best case" configurations to beguin with with this gear.
Not sure where to look for such teplates. I have part of the network set up but not the WND930 or the WC7500.
Any comments or suggestions are appreciated. I need all the help I can get.
Tepasquan
California
I just want to follow-up on this. Were you able to access and read the articles I've shared? Let us know if you have further questions.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Hi Tepasquan,
Welcome to the community! :)
Let me share the following articles below that might help as your guide in your network setup:
Kindly read also pages 44-51 of the WC7500 user manual about High-Level Deployment Scenarios.
DaneA
DaneA
- TepasquanAspirant
Hi Dane,
Thanks for the links and the follow up. I have not yet deployed the WC7500. I bench set up the AP's.
I am going to use the Single VLAN configuration similar to the sample but with three APs.
I will have questions as I find out how much I don't know.
Thanks
Tepasquan
