kloenie_nl's avatar
kloenie_nl
wireless access point WNDAP360 and new type AP's
hi there,
We have 20 WNDAP360's the admin is gone and nobody knows the passwords.
Reset it all is not wat we want.
we are thinking of buying a new AP make that the main AP and connect the remaining old AP's on that AP.
Is that possible ? And what netgear AP do we need then ?
thanxs
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    kloenie_nlm,
    Welcome to our community! :)
    This may only work if the WNDAP360s are assigned as a DHCP client and not assigned with a static IP. So what you want to do here is to just add this fully configured to a new AP is that correct? If the APs are working just fine, why do you need a new AP?
    John
    NETGEAR Community Team
    • kloenie_nl's avatar
      kloenie_nl
      thanxs for the reply,
      Nobody has the login/password for the AP's.
      So the only thing i can do is reset te old AP's and configure them on a brand new one.
      We want new one's because i want to expand the range to other locations.
      • JohnC_V's avatar
        JohnC_V
        kloenie_nl,
        Thank you for your response. Yes, we can only do a hard reset on all the APs that you have in order for you to reconfigure it. May I know if it is connected to a wireless controller or it is working as a standalone? Might as well update the firmware to its latest version after resetting it.
        John
ProSupport for Business
