guido79
Mar 28, 2018Tutor
AC1750 no IPv4 addresses via DHCP
Over time (~6-weeks), my router cable modem stops providing IPv4 addresses on my network via DHCP causing devices to default to a 169.x.x.x Self-Assigned address. They still receive an IPv6 address but when navigating to IPv4 websites like ford.com or pge.com, web sites fail to load. The only solution I’ve found is to factory reset router and manually configure my settings. Is my router dying or can I fix with an updated setting?
- DarrenMSr. NETGEAR Moderator
Hello Guido79
Have you double checked with your ISP they have your modem properly coded into there billing system seem like the unit becomes bridged and is acting like a modem only.
DarrenM
- guido79TutorThanks! We’ll give Comcast tech support a call when the issue comes back.
- vkdeltaNETGEAR Employee Retired
please PM me. We iwll need to debug with you.
- guido79Tutor
