eetee's avatar
eetee
Allow wired server to communicate with Guest Network (R6220)
 I have:
- a R6220 router running the V1.1.0.86_1.0.1 firmware
- a NAS connected to the network via a cat6 cable.
- the Guest Network is enabled and is isolated from the rest of the network
I want the NAS to use both my 'normal' network and the Guest wifi.
Can this be done?
Can this be done without making the NAS the DMZ server? (I prefer not to completely expose the NAS to the internet...)
Cheers
eetee
  • > - the Guest Network is enabled and is isolated from the rest of the
    > network
       That sounds to me like a contradiction.  Either the guest devices
    _are_ isolated from other LAN devices, or they're _not_ isolated from
    other LAN devices.
       I know nothing, but it's not obvious to me that "making the NAS the
    DMZ server" would allow isolated guest devices to access it.  It _would_
    allow incoming connections to the NAS from the outside world.
    • eetee's avatar
      eetee
      Presumably if the outside world can communicate with the NAS unhindered, then anything connected to the Guest Wifi can as well...
      This is less than ideal though.
      Ideally the interaction between the all my devices/servers on my network with the internet remains unchanged, but the NAS can communicate with guests.
      • > Presumably if the outside world can communicate with the NAS
           _You_ might presume that, but I wouldn't.  Again, with no actual
        knowledge, I'd expect the DMZ implementation to resemble a broad
        port-forwarding rule, and the guest-network restriction to be a
        firewall-like rule.  Although a rational policy might treat these cases
        similarly, I would expect the actual implementations of these features
        to be quite independent.  An experiment ought to resolve the question of
        whose guess is better.
        > with guests.
           I understand what you want, but the NAS just another device on your
        LAN.  Either a guest can communicate with a device on your LAN, or it
        can't.  And that (I claim) is independent of how the outside world can
        communicate with a device on your LAN.
  • Can't be done.  "Allow guests to see each other and access my local network" is applied to all. Your router does not have VLAN feature so you need to use another device that could do it.
