Brandonrodr
Jun 21, 2020Follower
Amber blinking lights
So my light went out and my cable modem started blinking, I tried restarting it with the button in the back but nothing happens.
1 Reply
Are you able to ping the modem or log into it?
It almost looks like your power supply isn't supplying the power. It'd be worth checking.
do you have a different adapter you could try. Make sure the voltage and polarity are the same and the amperage is at least the same.
