Idkanythingguy
Mar 06, 2021Follower
C7000 psn/duel consoles
My roommate just bought a C7000-nighthawk router/modem. We’ve never had this issue before but whenever we try to connect to the internet or play cod, our nat types are 3 and strict. He’s been messing around with port fowarding and dmz, but the only success was making “his” console nat type 2 and moderate. We can’t get mine and trying too his is now back at 3. Any help would be appreciated!!!!
1 Reply
> [...] We've never had this issue before [...]
Think for a moment. How much do you expect the non-psychics in your
audience to know about your "before" situation?> [...] He's been messing around with port fowarding and dmz, [...]
Think for a moment. How much useful information do you expect a
non-description like "messing around with" to convey to the non-psychics
in your audience?Are you trying to forward the same ports to two different devices? I
wouldn't expect that to work. (Perhaps "duel consoles" is more apt in
this case than "dual consoles" would have been.)> [...] We can't [...]
"can't" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
